Ohlins HVA ITCs on SWM
NSR
Message par NSR »
you have cut the final hydraulic piston
No, just the spacer between shims and the piston.
The original shocks were Marzochis and not very good ones.
I have done some testing, they work very good.
Sunshine Coast
Australia
Nice and interesting work Noel, tell us about the results of the riding test. :cool:
marquet
Message par marquet »
Oui,plusieurs personnes font deja ça,tu vires le piston corte et Cosso,tu mets un piston et clapets Olhins,et tu remplis ça avec l'huile Ad'hoc...meme principe que le montage Corte et Cosso,donc sans probleme...
fmace
Message par fmace »
marquet a écrit :Yes,it's a nice work,and a good change for your rear shocks,I put ohlins on all my bikes,they are reliable,very performant,the particularity of Olhins shocks,is the very good traction in all condition,the Corte Cosso rear shocks are good too,but the original oil fitted is shit :D,if you could rebuid your original rear schocks,fitted it,with Ohlins piston,and Ohlins oil...and after you have nice original rear shocks,with Olhins performance :clin:
Hi marquet,
Do you know who can do that upgrade to the Corte Cosso shocks ?
marquet
Yes,nice modification,you have cut the final hydraulic piston :clin:
marquet
NSR
Message par NSR »
Rebuild shocks
The red shocks came on the SWM.
Here they are with the ITC springs.
The ITC springs were too soft so I put a set of duel rate springs.
Even cut down by 20mm the hydraulic bump stop works and they have made the SWM even better to ride.
Cheers
Noel
Sunshine Coast
Australia
NSR
Message par NSR »
I have made a set of Ohlins ITC HVA shocks fit my SWM.
The SWM needs 420mm shocks. This is a standard ITC shock.
These are 420mm Ohlins, just right for the SWM
On the ITCs I have cut down the body, shaft and hyd bump cup by 20mm. I have also removed a spacer and changed the bottom eye.
This brought the length back to 420mm.
Cheers
Noel
Sunshine Coast
Australia
