1980 Cagiva RX250 engine gear cog
1970>1985 CROSS ENDURO
jodygibbons
Message par jodygibbons »
Thank you both :)
Bikes: Cagiva RX250, Cagiva MXR250, Cagiva WMX500
wima
Message par wima »
Schön das du ein Zahnrad gefunden hast .... viel Spass
Cagiva RX 125 1981
Cagiva RX 250 1981
Suzuki PE 250X,
Suzuki PE 175Z
GREAT !!!! :)
jodygibbons
Hi Jean-marie,
Sorry I should have kept you all updated. I have found the elusive idle gear cog :D Julien had one for me and I have it here now in the UK.
I did try contacting Lando Mobile on several occasions about their part but I never got a response :( But I have the part now so all good.
Once I have the RX engine casings shot-blasted and repainted I am then ready to do the rebuilt :)
Many Thanks
Jody
alors , des nouvelles??? :hein:
jodygibbons
Hi all,
Just to now confirm it is the idle gear that is broken. Part Number: 800029612.
Many Thanks
Jody
jodygibbons
Thank you Jean-Marie,
I have emailed Lando Nobile this morning looking to purchase these items. Hopefully they will fit and do the trick. It's abit of a gamble but if I can get both cogs in theory in could work :D
Many Thanks
Jody
Modifié en dernier par jodygibbons le 05 août 2021 13:10, modifié 1 fois.
Modifié en dernier par jmb le 05 août 2021 09:51, modifié 1 fois.
jodygibbons
Good evening Jean-Marie,
Thank you for taking time to try and find that relay cog.
The idle gear has also changed reference for 1981. 800029612 (1980 parts manual) to 800034303 (1981 supplement parts manual).
I think I would the 1981 idle gear to try with the 29 tooth relay gear, so both cogs to make this possibly work.
I did a proper photo and measurements this evening too on my current 30 tooth relay cog.
Many Thanks
Jody
you re welcome , I spent a lot of time for your gear , but impossible to find....
on the add 1981 , the idle gear has refence change?
If no , the 29 one should fit.
Modifié en dernier par jmb le 04 août 2021 19:09, modifié 1 fois.
jodygibbons
Hi Jean-Marie,
Thank you for your efforts :)
Yes I understand this particular part was changed or updated in later models of the RX and MXR. I understand the earlier models had 30 teeth and then later models from 1981 had 29 teeth. The part number gets updated from 800023590 (1980 parts manual) to 800034305 (1981 supplement parts manual).
It could work but I think I would need to change the gear it works too because of the difference in the number of teeth.
Many Thanks
Jody
I found this , but seems have 29
jodygibbons
It has 30 teeth in total.
Many Thanks
Jody
how many tooth joddy??
29 or 30 ?
Modifié en dernier par jmb le 04 août 2021 13:35, modifié 1 fois.
